Hello Bill
I tested your test.vi using PCI-6025E on a Pentium 1.7Ghz and it runs fine.
A possible solution that I used when my PC was no so powerfull, was queues. The adquisition part fills a queue and, in a parallel process, the analisys part empties it and does its work. this and the use of different threads, can solve your problem.
Hope this helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
