Error 200279
I am creating a VI for acquiring ECG signals. I am encountering an error 200279. I searched about it online and got to know that I will have to add DAQmx read property node for available samples per channel. I made the necessary chages but still it is giving me an error.
Please suggest me a solution for this.
Thank you.
(3,872 Views)
I am new to LabVIEW. I would be greatful if anybody could help me on this as soon as possible.
Waiting for the reply,
Thank you!
(3,867 Views)
Thank you!
Can you try this:
This mean that you wire the number of available samples to the read vi.
Not sure if it works in your case.
Br,
/Roger
(3,856 Views)
Did you try with these possible solutions?
Why Do I Get Error -200279
(3,836 Views)
Hello Roger,
Thank you very much for your reply. But I have a doubt: So if I connect "Available samples per channel" to the "read VI" as you have suggested then what happens to the connection between "samples to read control" and the "number of samples per channel terminal" of the read vi? Because if I connect "available samples per channel to the read vi then it gives me an error related to the connection\wire between "samples to read control" and the "number of samples per channel terminal" of the read vi.
Is there any other solution to this problem?
Thanks again,
Waiting for your reply.
(3,814 Views)
Hello fromm8,
Thanks for your reply.
Yeah I have gone through it. But as I said I am new to LabVIEW. So I really don't know which one works in my case. So I asked the question.
Thanks again.
(3,808 Views)
and what values are you using in your front panel? So I can reproduce the error
(3,786 Views)
