Error-200279
Hi all,
I have looked into few threads on this error. But i dont understand whats wrong in my code. I have created a buffer with no luck.
I have been to acquire continuous samples from strain and vibration sensors and do the processing(FFT) on the data. The VI runs fine for sometime and throws the error shown in the attachment  for Vibration .vi(similar error for strain .vi).
Can anybody help me where am going wrong.
Thanks in advance.
KM
(3,235 Views)
This error is usually related to the fact that your application is not keeping up (the reading of samples) with the hardware sampling.  I think it means that the samples that your are asking for have been overwriten on the hardware.
This is usually a software issue, where you need to do some optimization.
(3,205 Views)
Too much processing that slows the acquisition loop. You should use a Master/Slave or Producer /Consumer architecture (Create new VI from template -> Frameworks -> Design Patterns).
Ben64
(3,188 Views)
