Error -200284 by starting the measurement a second time
Hi everyone.
I have a question. We use Labview 7.1 and have a PCI6220 in combination with an a/d converter.
My program runs good. When i start, there is a whileloop that runs continuously and shows the data (after daqmx read) in  a chart.  I created one task with two signals.
Then if i put a button another measurement starts, and the first one is closed. When this measurement finished, the first loop runs again.  (hopefully somebody understand it ;S )
But then there is a problem. If i try to put the same button for the second measurement again, nothing happens. I only see the error -200284. How could it be, if in the first time works everything so great??
I read allot about the error, but in my case it has nothing to do with sample rate or timeout etc. I checked allot.
Both measurements start with "start" and stop with "stop". I use a high buffer and so on...
For the second measurement i use a triggersignal for start the data aquisation. . Could this be the problem?? The signal comes from a moving-table. But why doesn´t it work if  i put the button the second time?
I read something about external clock? Do i need this in my case? And if yes how  do i create on. Where is the place... at the timer vi ?
I hope so much that somebody can help me or give me some ideas to check.
Thank you very much.
(3,051 Views)
Hi Anni,
do you create the task at the second run again? Can you show us some code?
Mike
(3,046 Views)
Hi.
I just create the task only one time at the beginning. In front of the loops. Both loops use the same route.
I have a really big and complex programm and i am not allowed to send it. But i will make some pictures.
Hopefully they help.
(3,044 Views)
Here are two pictures. The external loop is running when i start labview ( i need no triggersignal).
If i put a button at the frontpanel the internal loop is running ( i need there a triggersignal from my table). It is a continuous measurement. So  if there are enough points the loop stops and the external is running again. But when i want to start my internal loop again i receive the error "-200284".
I am so sorry for the disarrangement.  But i was in a hurry.
(3,040 Views)
Hello.
After a few tests maybe I know where is the problem. But until now i can´t solve it.
The internal loop has a trigger configuration. When i put the trigger off everything works fine. When i put it to Start - Digital Edge the internal loop runs only for one
measurement. This measurement is ok, there is data aquisation. Buf if i start the measurement a second time... there is a problem and no data aquisation.
Could it be, that i have to choose another configuration for the trigger and if yes what should i take?
The trigger signal comes from a moving table. It is a normal rectangular funktion.
What is when the table send the signal only one time or to an unfortunatly time??
How long is the "start" vi waiting for a signal and when does it search for the trigger?
Thank you very much for your help.
(3,004 Views)
