Showing results forย
Search instead forย
Did you mean:ย
Error 200284 occurred at DAQmx Read (Counter U32 1Chan 1Samp).vi:5
Hello, My name is Jose, Im working with maria and Dr. Tom Harrison. I checked the links and routes as you recommended. It turns out that one of the routes on the graph we need is white which i understand means it is unavailable. IS there a way to make it available or turn it on.
Thanks, Jose
Message 11 of 12
(625 Views)
Hi Jose,
Unfortunately there is no way to internally connect the white route. There is more information on the device routes in this article. If you wanted to, you could try connecting them externally or importing an external signal to accomplish this task.
Kent
Message 12 of 12
(598 Views)
