Error -200453 for simulated 6537 on LabVIEW 2011
I'm trying to use a simulated 6537 for simulated data acquisition. In MAX I've added a simulated 6537 but when I click 'Start' in the Test Panel I get the following error:
Error -200453 occurred at Tets Panel
Possible Reason(s):
Specified timeout value is not supported. Supported timeout values are 0, up to 4294967, and -1...
Specified Rimeout (in seconds): NaN
I get a similar error if I create a task for this device and then try to run it, even though I specified timeout in the 'Advanced Timing tab for the task to be -1, 0, and other values.
(2,469 Views)
Hello Maxymoos,
I have attached a screenshot of my MAX with the devices and interfaces expanded, could you please take a similar screenshot of your MAX and reply here with it?
I would also like to check that you have the latest version of NI DAQmx installed?
Kind Regards
Dan Vickers - Applications Engineer UK and Ireland
(2,445 Views)
Thanks Dan, I re-installed and it now works fine - I had some install issues!
(2,429 Views)
