Error -200457 occurred at DAQmx Read
Hi
I read the data using DAQmx 9.4 VIs. First time everything is OK, but when I try to run my program second time
I get a massage "Error -200457 occurred at DAQmx Read, Possible reasons: Specified property is not supported, because the task is not input task"
and my acquisition card does not read any data.
I call a big VI out of another big VI and every call all acquisition/generation tasks (DAQmx) are reinitialized.
Any ideas about the error ?
I attach the ScreenShot of this error message.
My config:
Windows 7 32 bit
Labview 2009
DAQmx 9.4
Acquisition card - NI PCI-6110
(2,837 Views)
May help if you could post the vi. Last time I saw this error i was trying to use a timing function not supported by the board. So its likely to be of that nature. Sorry cant give much more but hope it points you in the right direction.
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,832 Views)
Thanks Tdarkins,
My VI is 420 Mb (with all sub-VIs).
I attach a simplified VI (only the DAQmx part) and screenshot of old version for DAQ initialization, when everything worked fine.
(2,824 Views)
Problem solved !
I have noticed that in older version of small VI (used by big VI) tasks were not cleared when pushing exit button (sceenshot, Acquire = false).
In my new version tasks were always cleared when pushing exit button.
So the solutions is -  not to clear tasks every time you stop the sub-VI.
(2,802 Views)
