06-28-2006 05:33 PM
06-28-2006 05:44 PM
As you know the task list is set up using MAX. So some problems could be that the task doesn't exist, you have an input connected to an output connection, you have configured the card incorrectly, the selector under the VI is set to output and you are using an input, or you are using the wrong VI.
Hope this helps
07-01-2006 09:48 AM
