Error -200609 occurred at DAQmx Write (Analog DBL 1Chan 1Samp)
Currently i'm using labview8.0. I'm experiencing an
Possible reason(s):
Generation cannot be started, because the selected buffer size is too small.
Increase the buffer size.
Selected Buffer Size: 1
Minimum Required Buffer Size: 2
Task Name: _unnamedTask<8D>
How can i increase my buffer size to solve this error?
(5,957 Views)
Hi!
Please see attached picture which shows the context help of the function to set the output buffer size.
BR, Christian
(5,953 Views)
I had the same issue and luckily found this post. Thanks Christian (where ever you might be now!)
(3,738 Views)
