Error-200684
Hello!
I found this project but when i try to run it, there is an error (error-200684). Why?
I'm not able to use labview program but i need a similar project.
I enclose to you the project and the immage of the error
Message 1 of 10
(5,587 Views)
What is the voltage that you reading?  I'm guessing it is a negative number.  That would cause your error.
Message 2 of 10
(5,581 Views)
In the immage attached the voltage is not negative, the voltage value is 2,46254 Volts.
Message 3 of 10
(5,574 Views)
Ok, just played with the VI for a little bit.
If the measured temperature is greater than the setpoint, then you will get a negative output from your PID.  You might need an offset in there or just limit the output to not go below 0.  I would just use the In Range And Coerce function to limit the range that your output could be.
Message 4 of 10
(5,569 Views)
Can you tell me step by step how, please?
I have never used labview.
Thank you.
Message 5 of 10
(5,564 Views)
Here's a snippet of the VI I made for troubleshooting purposes.  I added in the In Range And Coerce function to the output of the PID function.
Since you are brand new to LabVIEW, I highly recommend taking some of the free online tutorials that are out there.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 6 of 10
(5,554 Views)
I tried to modify the project on your advices. I compared your scheme with mine.
However the program don't run.
Message 7 of 10
(5,540 Views)
You still need your divide by 100 in there.
Message 8 of 10
(5,537 Views)
where?
Message 9 of 10
(5,532 Views)
Hi Vitamina,
since you are new in LabVIEW programming, let's try to follow the instructions in this tutorial.
I think it will help you.
Kind regards.
Cla_CUP
NI ITALY
Message 10 of 10
(5,496 Views)
