Error: 200983 - Current - Continuous Input SensorDAQ example
Hi all, running into an issue running the sample example. Things seem ok when I run it with logging mode set to 'off' but when I set it to 'log and read' I get an error:
error -200983 which tells me that I can only get the specified property while the task is reserved, committed or while the task is running.
Attached is the base vi. I've tried doing what it says here:
http://digital.ni.com/public.nsf/allkb/0B861D6AB4173E668625788F00548662
but maybe I am not putting it in the right space. Tried probing but nothing.
Still being a complete amateur to LabView does not help..
Message 1 of 1
(3,429 Views)
