Error -2146822260 Set Footer Word Report
As it says in the title I am using LV 7.1 with Report Generation Toolkit.
I am trying to set the footer of the document.  I am using a ReportTemplate.doc with bookmarks from 3 items - they are working correctly, and all the other information I am adding to the document is formatting.
When I try to Set Footer and simply feed it text into Center Footer Text it returns
Exception occurred in Microsoft Word, The range cannot be deleted.. Help Path is C:\Program Files\Microsoft Office\Office11\1033\wdmain11.chm and context 25508 in Word_Insert_Footer.vi -> Set Report Footer Text.vi -> “My vi”
Error Code -2146822260
Any clue as to why?
Ryan
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 1 of 11
(4,783 Views)
Hi Ryan,
I have not seen this problem before.  Can you attach a simple VI that demonstrates the problem?  Also, what version of the Report Generation Toolkit are you using, and what version of Office are you using?
Let me know,
-D
Message 2 of 11
(4,783 Views)
Report Toolkit 1.1.1
It must be something with the document I am using because when I remove the template.doc input and just use a "new" Word document it works fine.
I'm going to try either fixing the template doc or creating a new one.  I'll let you know.
EDIT:
Checked the footer range of the Document and somehow a blank one-line table was saved in that location.  Deleted it and now everything is working.
Message Edited by RVallieu on 04-20-2006 08:46 AM
Message 3 of 11
(4,774 Views)
Glad to hear it...let me know if you have any additional problems.
-D
Message 4 of 11
(4,767 Views)
When I was creating sample report with header , Footer and title, it shows error with id : -2147417846  and some messages.
Could you please guide me how to nullify this error message.
Message 5 of 11
(4,213 Views)
Well, the message said the application is busy. There is not much to say without seeing your code. Is there a dialog window open waiting for user action?
Ben64
Message 6 of 11
(4,179 Views)
This is the snapshot of the dialog  box which i get it while running the program
Message 7 of 11
(4,144 Views)
Post your vi.
Ben64
Message 8 of 11
(4,127 Views)
Message 9 of 11
(4,100 Views)
It's working well on my PC (LV 2015, Office 2010, Win7). What versions of LabVIEW, Word and what OS are you using?
Ben64
Message 10 of 11
(4,085 Views)
