Error -2146827284 When Attempting to Open Excel Workbook
Using LabView 6.0 and OfficeXP's Excel... I am receiving an activex error: -2146827284 when I try to programatically open an excel workbook.  The thing is, this is after I have previously opened and closed another workbook via activex.  I searched about this error on the forums, and while there were a few entries there were no hard solutions posted.  Please help.
(6,678 Views)
check file path and make sure it is correct, also make sure you are not sending data to a location that has not been allocated yet. A simple snapshot of your code would be much helpful.
-Joe
p.s. make sure you closed the Excel instance completely. Use "Ctrl+Alt+Del" to check if another instance of Excel is in memory.
(6,674 Views)
Thanks for the help that fixed my problem for the initial error, but I still get the same error when I am writing a U16 2-D array to a range of cells. This is strange because the same code is used elsewhere and does not throw the error, but the data type is instead a Dbl 2-D array.  Unfortunately, I am unable to post the code.  It is on a stand-alone classified pc.
(6,660 Views)
I had similar problem before. convert the U16 to DBL and then write it. You can format the cells in Excel with or without decimal points.
-Joe
(6,652 Views)
