Error -2146827284 excel set graph font & set graph scale
When I´m using excel set graph font.vi and excel set graph scale.vi, I get error Error -2146827284. If I remove these VI´s my .VI is working without any problem. I´ve tested many kind of differnt settings
but cannot get it working without getting this error.
The thing I want to accomplish, is to get units on x and y axis like "time" and "weight" for example, that should not be so much of a problem, but what I understand, using set graph scale.vi is the way to do it.
Please help.
(2,662 Views)
Hi patte_lfl,
Just to clarify, could you please open the Column Graph (Excel).vi in the NI Example Finder found in <LabVIEW> » Help » Find Examples... and run the VI. Do you receive the same error? The -2146827284 error is a generic Microsoft error code that you may encounter through various different functions and implementations whilst using the Report Generation Toolkit; so it may be hard to clarify at this point why you are encountering this error.
Please run the example I referenced first; then we'll be able to debug in what way your code differs if the VI and do some reverse engineering to get your VI working! In the mean time I'll play with the VI you created to see if I receive the same response.
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
(2,606 Views)
