‎11-29-2012 08:18 AM
Hi all,
I'm fighting in front of this error which occur and does not want to go away (even after trying everything)...
The error (-214713840) is happening when trying to set back the Scan Engine Mode to actif.
It says: "The slave device could not be found. The positional addresses within the LabVIEW project are inconsistent with the actual network topology. [...]"
I was trying to program the detection of the loss of a CompactRIO chassis when this error first occurr.
I have 2 CompactRIO "EtherCAT" connected to a RT computer.
Thanks for all the help or suggestion you can provide me 😉
Cheers,
Laurent
‎12-10-2012 09:33 AM
Hi Laurent,
I don't know if your problem has been solved but I prefer asking.
Are you sure of the error code you encounter ? I don't find it in the manual or other places.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
‎10-29-2014 08:09 AM
Undeploy previous / deploy new configuration from Labview project explorer might help. It resolved Error 2147138480 to me.
