Error -2147220612
I'm trying to use the System Configuration functions to change network adapter settings; but when I call Save Changes, I always get error -2147220612 (NI System Configuration:  (Hex 0x8004037C) None of the changed properties can be validated.)  What is causing this error, and how do I get around it?
(3,839 Views)
This may be one of those situations where the Error Message is not quite right.  I suspect that you might be running up against a UAC (privilege) issue.  Are you running Windows 7 or higher?  I don't know precisely what you are doing, and can't test or demonstrate it for myself (because you didn't attach the VI in question -- hint, hint), but I can imagine that changing Network Properties might require elevated privilege.
How about posting the VI and letting us have a try at this?
Bob Schor
(3,811 Views)
Here's an example.
(3,800 Views)
