03-20-2006 10:47 AM
03-20-2006 10:57 AM
In my episode, if a channel gave me that problem on a fresh MAX load, there was nothing that could be done to modify it. Didn't matter if I restarted MAX again or not. It had to be deleted. And if I tried modifying a working channel after having received the error, the other channel would give me that error too. So, somewhat painfully, I tried modifying my channels one by one from fresh reloads of MAX. If it errored, I deleted it, reloaded MAX, and recreated the channel, then moved on to the next one, tried modifying it, if it errored, deleted it, reloaded MAX, etc.
This very 'picky' linear methodology was the only thing that worked for me, allowing me to successfully identify which channels were "corrupt" and replace them. I don't know if you are trying to create a new task on a fresh load of MAX or not, but if not, or if you are not sure, perhaps try doing it that way (and deleting the old one before reloading max).
Again, this is by no means an elegant work around, but it worked for me being that there currently is no NI help file for this. I still would love to know more details on the cause of the error myself aswell.
03-20-2006 11:30 AM
03-21-2006 01:24 PM
03-21-2006 03:04 PM - edited 03-21-2006 03:04 PM
Message Edited by McKala[DE] on 03-21-2006 03:05 PM
Message Edited by McKala[DE] on 03-21-2006 03:06 PM
03-22-2006 06:21 AM
03-22-2006 06:28 AM
For some reason it won't let me attach the zipped MAX folder, perhaps it's too big? Any ideas?
Thx
03-22-2006 08:44 AM
03-22-2006 09:53 AM
05-04-2006 12:23 PM
