Error -2147221480 occurred at Building DLL stub
When I build a Shared Library, I get following error message
Error -2147221480 occurred at Building DLL stub.
This can be caused by illegal function or parameter names. Please verify your names are legal C identifiers and do not conflict with LabVIEW headers
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
Can anyone help me out regarding this error...
Message 1 of 10
(4,706 Views)
To begin with, do didn't say whether you have checked the two possible errors listed in the error message:
1) the function and parameter names are legal C identifiers
2) the function and parameter names do not conflict with LabVIEW headers
How many functions does your DLL have? What are their names?
What parameters do the function(s) have? What are their names?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 10
(4,702 Views)
HI,
Well my dll has one function
Function Name: PeakDetect
Input Parameters: double[], double[]
Output Parameter: double[].
Message 3 of 10
(4,684 Views)
Try changing the name of the function itself to something like MyPeakDetect - anything that it would be less likely that NI would have one named the same. Also what are the names of the parameters?
Mike...
LabVIEW Champion
Message 4 of 10
(4,680 Views)
Well I tried changing the name of function...But i get the same error...
Parameter names as
Input Parameters :XArr,YArr
Output Parameters: OutArr
Message 5 of 10
(4,669 Views)
Ok, now try changing the parameter names to something unlikely.
Mike...
LabVIEW Champion
Message 6 of 10
(4,667 Views)
Did it...Again same error
Message 7 of 10
(4,660 Views)
The last test, what did you rename everything to?
Mike...
LabVIEW Champion
Message 8 of 10
(4,652 Views)
Dear Nileshv,
Make sure you don't have more than one control with the same name. Some controls might be hidden from the front panel (if you chose that option).
Kalin T.
Message 9 of 10
(4,638 Views)
I got the same error, and also I tried creating a new labview project, with a simple vi that passes only the input value to the output. I suscpect is something with the LabVIEW installation, since I tried in the same computer but inside a virtual machine running a different labview version, basically the same labview project and it was builded without problem.
I'm opening a SR, I will share the results.
Guillermo Oviedo
R&D Software Engineer
CLA | CTD
Message 10 of 10
(3,574 Views)
