Error -21872 occurred at mod_Validate RS code prms.vi
I am receiving the error message "Error -21872 occurred at mod_Validate RS code prms.vi"  Can any body guide me how to fix it. See attached VI for further details.
JK
(2,929 Views)
I would to like add that this error  is related to reed solomon encoder.
If I usen n = 15 and k = 11, it works fine. But if I use n = 64 and k = 32, it does not work and gives error.
Can anyboody guideme how to fix it.
JK
(2,889 Views)
Hello JK,
You have entered an invalild n value. As the error explains, “The relation n-k=2*t (where t is the error correcting capacity in symbols) must be satisfied for any valid RS code. For a "normal" RS code, n must be a valid power of two minus one."
n = 15 works, since log2(15+1) = 4, and 4 is an integer number.
n = 64 does not work, since log2(64+1) = ~6.022367, and ~6.022367 is not an integer number.
Matthew R.
Field Applications & Systems Engineer
(2,851 Views)
