Error 224606
I used labview 8.5 on windows XP to run a test program. "Error 224606" shows up, i could not figure what this error is about.
Could anyone help?
THanks
(5,059 Views)
The error -224606 is an internal software error in the MIO.  What hardware are you using?
(5,056 Views)
I am using NI labview 8.5 on laptop with Windows XP , how can i solve this error?
thanks
(5,053 Views)
What hardware is the code trying to communicate with.  If you are getting a internal MIO software error there must be a MIO device right?
(5,047 Views)
thank you for your reply,
The hardward i am using is NI SCXI-1001(machine) with NI SCXI-1521 (module) with NI SCXI-1317 (card)
(5,015 Views)
OK , I looks like you've got a driver problem.  I'd recommend trying to install the newest device drivers,DAQmx, VISA and IVI compliance packages.
(4,996 Views)
Hi kylin,
      Jeff's suggestion of reinstalling the drivers is a good one and I would recommend trying that first.  This error has been seen in another case where the task is being cleared when there are still samples in the input FIFO.  While we don't have much documentation on this, one thing to try would be to put a delay before you clear the task.  Have a great weekend!
(4,983 Views)
