Error - 229771 occurred at DAQmx Create TAsk.vi:4440004
After installing Ubuntu 22.04.5 LTS and Windows PowerShell to upgrade our control system ARTIQ (version 6 -> 8), I got this error when I run one of our Labview programs. I'm not sure if installing Ubuntu and updating ARTIQ using linux can cause this.
I'm using NI Labview 2013 64bit.
Also, I found that these files generated or adjusted whenever I run the problematic Labview program, which I don't know what they are.
How should I solve this issue?
(583 Views)
Is LabView 2013 64 bit compatible with Windows 10 22H2? (We had to updated it from 21H2 to 22H2) We did not have any issue with Windows10 21H2 so far.
(561 Views)
The first supported version is LV2015 SP1.
Reference: NI Product Compatibility for Microsoft Windows 10
https://tmesystems.net/
(549 Views)
Labview 2013 worked really well with Windows 10 21H2 before we upgrading it. If it is not compatible with windows 10, I'm not sure how I could use this so far.
(501 Views)
NI-MAX is the Measurement and Automation eXplorer tool that works like an advanced Device Manager for NI software and hardware.  This error is a MAX error too.  You should be able to reset your MAX database and clear this.
See the KB article here:  NI-DAQmx Error 229771: Internal Software Error Occurred in MIG Software - NI
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(492 Views)
I got the same MIG software error when exporting NI MAX database for backup following the NI online intructions, so I was afraid of losing all the previous relevant files when resetting things. However, when I just ignore this backup and reset the NI MAX config database, everything worked fine. Thank you!
(479 Views)
