Error-229771
Whenever I try to run my program this message pops up
Error occurred at DAQmax Create Task.vi:4440002
(3,776 Views)
Looks like: Error -229770 Occurred at DAQmx Create Task.vi:4440002. Have you tried those steps already? Did you see any other errors, perhaps when force-reinstalling the software? Has DAQmx worked before in this machine?
(3,734 Views)
Accepted by topic author Des360
Thank you for reaching out regarding this issue. It seems as if this issue due to a corrupted MAX database file. From the MAX Explorer we were able to do a program reset under Reset Configuration data which fixed the issue.
(3,721 Views)
