Error -23011 occurred at LabVIEW Analysis ODE Solver/inconsistency in dimensions of X(0), F and X!
I am wondering why no one from NI bother to solve this issue. I am still unable to resolve this issue.
Looking forward to hear from someone else.
Thanks.
Regards
Hasan
Message 11 of 13
(1,187 Views)
Accepted by topic author HB.
Hi HB,
I was checking your code and i found out that in the last example that you attached, the problem is that you have declared three equations but only declare two variables. That is the error in the vi. For example your variables should be C1, C2 and C3 and should declare initial values for the three of them. Also i have found an example of how to use the ODE solver with a circuit DE, you can find the example by going to the help tab, find examples, search and under ODE circuit. Hope you can solve your issue.
Randy
Randy @Rscd27@
Message 12 of 13
(1,162 Views)
Hi Randy,
Thanks for your reply. I have already been to that example. I got it fixed little while ago, and yes the problem was the same you mentioned. Thanks anyway.
Regards
Hasan
Message 13 of 13
(1,158 Views)
