Error -2367 occurred at External Model (BLDC Motor Circuit)
Hello. I am facing the error attached below while co-simulating Multisim and LabVIEW. I have attached all the files I am using. I need your help to resolve this problem. Thank you.
(1,242 Views)
Hello
As I understand from the screenshot, the error is coming from the Multisim.
I was trying to run the Multisim circuit that you have provided but received an error which "There are no valid output variables".
Have you defined them on your side?
(1,178 Views)
