Error -2367 occurred at External Model in Esimmll.vi/Control & Simulation Loop
Dear all, I am very new to Labview programming. I try to simulate a simple RLC circuit using Multisim co-simulation with Labview. I modeled the plant and control system in Multisim and Labview, respectively. However, when I want to run te model I get the following error! Labview 2018 Multisim 14.2 Error -2367 occurred at External Model in Esimmll.vi/Control & Simulation Loop Possible reason(s): Control Design and Simulation: The shared library corresponding to the external model returned an error. (M200) I would be very grateful if you could help to fix this error! Thanks for your time!
(1,559 Views)
Sorry,I don't know why I can NOT attach the VI and multisim files to this, but I have to say that I changed the time steps value as what described by other threads. that still did NOT work.
(1,541 Views)
