Error -2372
I am a newcomer to labview and have recieved error -2372 when using a 1D lookup table. I was trying to have one input relate to one output in the control design and simulation module. Unfortunately, labview does not allow decreasing lookup functions, of which mine is one! Hence the error above occurs.
Does anyone have a work-around or explanation to this problem? It seems a bit odd that you cannot have a decreasing function...
Thanks in advance!
(2,757 Views)
Hi Labnewb,
Thanks for your post and welcome to the forums!
What function are you trying to implement? Do you have a VI with the function implemented?
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(2,732 Views)
