Error -2417417851 using Report generation toolkit
I try to use the Report Generation toolkit (Version 1.0.1) for MS Office und the example "Generate Report from Template (Excel).vi" return an Error -2417417851
I run Labview 6.02, on Win2000 German, and use Office 97 (Everything is installed (included MS Graph))
Did someone experienced such a problem and found a solution?
Thank you for your Help!
(3,033 Views)
Is LabVIEW and Office both German? Under Control Panel >> Regional Options >> General, is the language set to German? How about under Regional Options >> Input Locale? Reboot if you make any changes.
I would suggest reregistering the nireports.dll. It is located in the National Instruments\Shared\NI Reports directory.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/4f811a9b23f1d46e862566f700615b7a?OpenDocument
Next, mass compile (Tools >> Advanced >> Mass Compile...) the LLB's in the \vi.lib\addons\_office
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(3,033 Views)
