Error 267 in System Exec.vi Windows 11
Greetings everyone,
I am trying to get a test program working on a windows 11 laptop that has, until now, been running on a Windows 7 system. After everything has been initialized, the program uses System Exec.vi to open a command prompt. At that point, a command is executed to initialize a board under test.
I get an error 267 in System Exec.vi when it tries to execute the CMD command. There are no paths connected to the vi as it is not required to execute the CMD command. I am wondering if it is an incompatibility between Labview 17 and Windows 11. I know the compatibility table shows windows 11 requires Labview 22 and above. The program does run up to that point however.
Any thoughts or suggestions?
(1,263 Views)
Not much help, but I'm using LV20 and Win11, and SystemExec.vi works as expected.
(1,254 Views)
Thanks. Not sure what else I would need unless I need a newer version of the runtime. I have installed Runtime 17 and NI Visa 17 for the communication portion of the test.
(1,241 Views)
For incompatible software versions, NI R&D did not validate it and thus it is not guaranteed to work.
On top of software version incompatibility, are you using EXE or VI?
Installers and executables are only guaranteed to work on the operating system they are built on.  For example, a Windows 10 installer or executable may not work as expected on a different Windows version (e.g. Windows XP, Windows 8, or Windows 7). Reference: Running Executables or Installers on Different Windows Versions
https://tmesystems.net/
(1,211 Views)
It is an exe. I thought it might be something like that but I was hopeful it was something I could do to make it work.
(1,205 Views)
