Error#3:"memory.cpp"line 563 Labview version 6.1
When I am processing data from harddisk, below messages comes ending labview session:
Contact National instruments
(3,252 Views)
Take a look at the following KnowledgeBase. Without some more information on how you are processing the data it might be hard to give you a difinitive answer. http://pong.ni.com/public.nsf/websearch/C8EB44CECE4BCD5D86256AFD004B2027?OpenDocument
(3,252 Views)
I have a similar problem that brings up the same error message when I try to dynamically load and run VIs in my LabVIEW executable. This does not happen when I run the VI version. I'm using the victl.llb (VI Control) library to load the VIs. Am I doing something wrong in loading the VIs or in building the EXE? Does it have anything to do with different paths to the VIs in the VI and EXE version?
I tried a second approach that runs the VI dynamically by opening a VI reference and call the RUN VI method. This, works occasionally and returns the same error. Please help.
(3,252 Views)
I can not open the link
(3,252 Views)
