Error 3005 using Database Connectivity Toolkit
I'm using the LabVIEW Database Connectivity Toolkit, version 1.0.132 with LabVIEW 8.5. When it tries to create an ADODB.Recordset object in the Conn Execute.vi, the "Automation Open" function node throws error 3005, "The specified object can't be created".
I've read somewhere that this may be related to an unregistered DLL or ActiveX component. Is there a way to find out what DLL this function uses? Any suggestions on other things to look for?
Mike
(2,879 Views)
Good Evening Mike,
This Knowledge Base article seems to show a solution to a similar issue. Let me know the results and if you see any errors in the process.
http://digital.ni.com/public.nsf/allkb/DE740209C3CC097D862571D2006DA0BD?OpenDocument
Have a good day,
Connor
(2,848 Views)
