Error 3008 opening Excel template to insert table
I am trying to insert a table from labview into and excel sheet for plotting. I used one of the standard templates in the examples to successfully run "New Report.vi", inserted my table with "Excel Easy Table.vi", and viewed it with "Excel Bring to Front.vi". I then created the plot I want from the inserted table, and saved the resulting workbook as a template. However when I tried to run my program again using my new template (so my excel plot would be updated with the new data) it gave error3008:
Labview error 3008
Automation Interface for the specified class cannot be obtained.  Check if the automation refnum type is the correct class for this operation in Excel_Get_Range.vi->Excel_Insert_Table.vi->Append Numeric Table to Report.vi->Excel Easy Table (num).vi:1->MyInsertCells.vi
Can anyone help - is there some other way I should save the workbook I want to use as a template? or some other standard place it should be saved?
thanks
Fred Engel
(4,233 Views)
Fred,
There is an input named "display alerts?"   on the "New Report.vi" that defaults to False.   Wire it to a constant "True".  This will allow the Excel errors and warnings to pop up.  Message in the Excel popup should lead you to the answer.  Can you post your code?
(4,227 Views)
