Error -307703 occurred at SE Dialogs.lvlib when importing dllinto veristand2021
I made a simple model by simulink2021a with MinGW 6.3
but when importing into veristand 2021 r3,such error occured
I checked again and again ,but can not find the reason .
untitled1.7z is my simulink source code.
my env variables are as below:
cry cry cry
what shall I do ?
(878 Views)
My CPU is AMD Ryzen 7 PRO 6850U with Radeon Graphics 2.70 GHz
(877 Views)
here is my simulink model settings
(873 Views)
(861 Views)
it seems these two sys variables really effect,path such as D:\mingw64\bin does nothing。
If I delete that two paths ,simulink can not build a dll , if I keep that two paths ,it build linux[rt(see from their names) dll.
What shall I do to take my MinGW 6.3.0 effect ? CAN I delete that two linux paths ?
(850 Views)
I just want  just to complie a model and run it on local PC
(839 Views)
I modified the sys variables as below:
after that ,cmd window can show gcc version 6.3.0.
but such error when imported into veristand is still.
(820 Views)
