Error 363513 when using the Labview Runtime Engine. No error when using Labview itself?
The software is throwing Error 363513 after building an executable and running it on the runtime engine. However when I use Labview, the error is not thrown.
They are using the same network, so we do not believe it is firewall related as the network is a stand alone at&t network.
Port used is 587
Outgoing mail server is smtp.gmail.com
TLS\SSL is true
Thank you
Message 1 of 1
(1,645 Views)
