Error-375006 unflatten from json
I have a TCP/IP communication protocol between Python and Labview.
LV sends data to Py and Py returns a confirmation back to LV. The problem is I am receiving a error-375006 when receiving the confirmation on the LV side.
Attached are both Py and LV. The error is regarding the unflatten from json but  I really do not know what I am doing wrong.
Any help is appreciated.
(3,510 Views)
Accepted by topic author SueLong
A few issues:
Your Python code is incomplete, there is no code to send a reply (ie. client.send(bytes(json.dumps(response),'utf8')))
In LV, your cluster constant on the BD has different labels than the one on your FP.  Not a problem if you use the right labels to build the JSON reply (the ones hidden in the BD constant), but that is a bit tricky.
When I throw in a reply from Python, the next problem is that the socket is immediately closed which causes the TCP read in LV to error out with Error 66.  Not a big deal as I ignore this error many times when I expect it, but you are feeding it into the Unflatten from JSON node so it will not work and instead errors out.
(3,470 Views)
Sorry, I think I have sent you the older version.
Here is the latest version.
(3,459 Views)
Yup, the error was because I had a different name in the BD!
Thank you so much!
(3,449 Views)
