I made a Labview6.1 based application that handle serial communication with six RS-232 ports. The program is intended to run 24 hours a day. After around 2 days of execution an error occurs. Here the reference:
Error 38 thread.cpp line 1938
What can be the root cause of this failure? I'm pretty sure it's not lack of memory/CPU.
Be sure that all the threads you oppened are all closed. For example if you put an "open VI reference" don't forget to put the "close reference" at the end of the task.
