Error 42 occurred at Property Node %28arg 1%29 in main.vi
Hi all,
I am trying to pass my image data to subvi .. using (Global variable ).
in that case i am getting
Generic error ?
(3,167 Views)
Need to see code in order to help diagnose this problem.
(3,141 Views)
Hi ..
Actually i am trying to make Two monitor application . (TWO FRON PANELS).
Main Vi makes Imgae process and showing result image in Subvi ..
Using global variable (Image data) method ..
1.In my Main project Code i am using Many property Node (Value) method to share my variable to other loop.
   So in that project if i use global variable it shows Error.
2. Once i remove all the Property Node (Values ) .. Global variable Sharing work fine.
(3,118 Views)
@SaranVenkateshS wrote:
Hi ..
REPEAT AFTER ME: Show me the VI.
(3,108 Views)
