Error 42 occurred at ni_tagger_lv_Write
I am trying to output an IMAQ Image to a network variable. However, when I run the VI I receive the error message "Error 42 occurred at ni_tagger_lv_Write", "Possible reason(s): LabVIEW: Generic error."
Is there some kind of setup I need to perform to get network variables working? All I did was add one to the project and configure it as a variant. As a side note, the program works fine using "single-process" variables as opposed to "network-published" variables.
edit: I am using LabVIEW 8.2.1
Message Edited by thorholiday on 06-25-2007 12:09 PM
(4,783 Views)
Does the error happen as the variable is being deployed or later in your program?
Also, can you create even a simple project that uses network published variables?  Try running the shared variable client -server project found in example finder.  If not, it may be that something (like a firewall) is blocking communication.
Craig D
(4,761 Views)
I think SV is not very stable in LabVIEW 8.2.1
http://www.vitst.com
Virry Test & Control
LabVIEW Certified Developer
(4,521 Views)
There is a problem sending certain datatypes to network published Variant Shared Variables.  This problem (Error 42) still exists as of LV 8.6.1.  See my post here:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=342875
-Jason
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(4,351 Views)
