Error 42 occurred when writing to data socket server?
Hi
Attached are two programs which use data socket to transfer a boolean value. I want to make sure the value only transfer one time. It occurred error 42 at the test server.vi when it write to the data socket server. How can I solve that? Are there any methods to ensure the data can be transferred one time? Thanks.
Bill
(4,120 Views)
I am using LabVIEW 7 and I did not see the error on my machine when I ran your programs.
From the way you want to transmitt data, I think you need to use TCP/IP instead of datasocket. This way you can be sure that the data only got read once. There are several shipping examples to get you started.
If you have LabVIEW 7 you might consider using the buffered datasocket. I am not sure if it will work in the way you want so experiment.
(4,119 Views)
