Error 43 in Write to Spreadsheet File (DBL)
GerdW wrote:
so it's a RIO: a RIO (usually) has no user interface and so you cannot open a dialog to ask the user for some settings (like filenames)…
More specifically, this is running on the RT System.  RT (typically) doesn't have a UI and therefore your dialog is just instantly canceled, causing error code 43.
But you also need to be very careful, depending on how much non-volitile memory (ie harddrive space) is availble on the sbRIO.  And also know that the sbRIO can't write to your C drive.  It can write to a network shared drive on your computer using the network address.
Message 11 of 16
(1,214 Views)
so does it means it is impossible to me to save a 2d array data using "write to spreadsheet"?
Message 12 of 16
(1,206 Views)
Hi yapp,
no, it means: you cannot use any dialogs on your sbRIO.
Use predefined path constants (with the restrictions given by crossrulz) and you will be fine!
Message 13 of 16
(1,204 Views)
Thx to crossrulz and GerdW. Now the error 43 is gone when i change the type of dialog in "Write to Spreadsheet.vi" to "No dialog". After that, i create a network folder from Map Network Drive. Is it correct to this stage?
Message 14 of 16
(1,194 Views)
Hi Yapp,
NEVER change any VIs in the vi.lib!
Create your own copy of that VI and do any changes you like on that copy! (Or even better: use some simple file functions (Open, Write, Close) with basic string formatting instead…)
Message 15 of 16
(1,190 Views)
I'm not sure about the Map Network Drive.  Where is that mapped drive pointing to?  And even then, whatever you mapped the drive to on your computer, the sbRIO will not be able to use that label.  Think of the sbRIO as its own computer (since it really is).  Would you expect my computer to be able to access your mapped drives?
What I typically do is make a folder C:\shared and then make that folder network shared.  Then other computers can access it via a network address in the format \\ComputerID\shared.
Message 16 of 16
(1,187 Views)
