Error 5 occurred at Delete
I have a simple VI that truncates a text file, but I get the error "Error 5 occurred at Delete" when it runs
Any takers?
(2,955 Views)
Hello Tui.
Your Truncate...VI should not be the problem. A good candidate for your error might be the code that wirtes to the LogFile: Is it possible that this code and your Truncate...VI run at the same time?
This would match Error.Code=5.
Regards, Guenter
(2,942 Views)
Hi Guenter
I don't see how my write code (enclosed)could be the problem as I close the file.
Have tried with time delays, but that made no difference
(2,935 Views)
Hello Tui.
Now I see it: You currently do not close the file in the inner case structure's "False" case of your TruncateLogFile.VI.
Regards, Guenter
(2,912 Views)
Thank You,
Sometimes the easy mistakes are hard to spot.
(2,909 Views)
