Error 5 occurred during build operation
Error 5 occured when I tried to build my application. I receive this message:
Error 5 occurred at Invoke Node in AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File already open.
NI-488:  Command requires GPIB Controller to be System Controller.
Method Name: Build:Application
Could anyone help me with this
Gilles
(2,687 Views)
What you are doing in your application? Are you calling or using any external files, i mean tet or excel files? If so are they opened while your application is running? If so please close them and try launching your application again and do you want to solve your problem very quickly? If so please post your code so that your problem can be easily identified.
Trying to help
Mathan
(2,672 Views)
@ Mathan: He is getting the error during the Build, not when running the application.
@ Gilles: What version of LabVIEW is it?
Christian
(2,645 Views)
