Error 5003 using Arduino Nano and Linx
I can't get contact with my Arduino Nano using LINX library in LabVIEW. Constantly get "Error 5003". I've uploaded the firmware onto the Nano board using the Makerhub firmware wizard and it's ok. I have for sure chosen right board and COM port. I've tried both LabVIEW 2015 and 2016. None works. I've tried to use Arduino MEGA board and this works perfectly.
This didn't happen before, seems like problem occurred on newest Nano board.
Anyone experience same problem? Solutions?
br,
paalbrok
(3,995 Views)
Good morning,
Would this be something that would be related to the problem that you are having?
Arduino - Labview Error 5003
(3,942 Views)
Sorry for being so late, upload firmware Linx for Arduino Uno (in the Arduino Nano board), then you could run your code without troubles.
(1,913 Views)
