Error 50103 - DAQmx error
You should have context help turned on at all times and actually use it. With it on, move your mouse over the index array function. In the help window, click on 'Detailed Help'. Read the part about 'resizing the function'. The little image of the funciton in the help window shows where you can drag the function to create more inputs.
Message 11 of 11
(500 Views)
