Error 5017
Hi guys!
Im new to LabVIEW and currently experimenting on a program using NI 6509 DIO. The problem is when i open my application, an error pops out stating Error 5017. Can anyone enlighten me on this one? By the way, Read HW Requirement is the first state of initialization in my project.
Thanks!
Angelo Alim
Message 1 of 10
(5,852 Views)
An chance of getting a peek at the code? Also does this error occur when you open the VI, or when you run it?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 10
(5,837 Views)
I don't remember any VI of that name. Where did it come from?
Message 3 of 10
(5,825 Views)
It occurs when i run the exe file i created. But when i run only the VI from the project file, it does not return an error. anything in mind what is happening? what may cause this?
Message 4 of 10
(5,820 Views)
i created an entire project and this VI is included in this sir.
Message 5 of 10
(5,819 Views)
What does that VI do? Did you create the VI? It sounds like something isn't getting included when you build the application.
Mike...
LabVIEW Champion
Message 6 of 10
(5,814 Views)
The VI uses DIO connected on switches as inputs and LEDs as outs. I use NI 6509 as my DIO. Yes. I created it. The project file is good, but then when i created my .exe file, the error then pops out. Anything in mind what is lacking?
Message 7 of 10
(5,808 Views)
Are you running the exe on the same pc as your development? Why don't you attach an image of the subVI block diagram or VI itself?
Message 8 of 10
(5,799 Views)
Does the computer you are running the executable on have DAQmx installed?
Message 9 of 10
(5,774 Views)
Yes it does. Im thinking that I am lacking something in my included files. Anyways, thanks for your kind replies.
Message 10 of 10
(5,764 Views)
