Error 53 manager not supported (myrio project)
Hello, i have a VI which is working correctly. when i added the VI to myrio project i got an error 53  at property node (arg1). possible reason : manager not supported. How can it be solved?
I really appreciate your help.
John Brew
(3,446 Views)
This error generally creeps up when trying to perform an operation that is not supported on a Real-Time target. So whatever property you're trying to access isn't supported on your RT target.
Cheers
(3,426 Views)
James is probably correct. To add a little bit, if you look at the detailed help there is a remarks section that gives a lot of information on where and how each property can be used.
(3,404 Views)
