Error 537300 running 32-bit LabVIEW
I am trying to run a program compiled with LabVIEW 32-bit. After installing the required LabVIEW Runtime 2014, the program starts, but after a few seconds, it shows an error:
Error 537300 occurred at an unidentified location
and then the application closes.
I do not have access to the original uncompiled program. Looking at the executable with Notepad, I found a line that seems to indicate it must be run with Runtime 2014:
%ProgramFiles%\National Instruments\Shared\LabVIEW Run-Time SOFTWARE\National Instruments\LabVIEW Run-Time LVRT 14.0 LVRTTable DLLWinMain lvrt.dll
So far, I have tried:
  • Doing a clean installation of the LabVIEW Runtime 2014.
  • Uninstalling all other versions of LabVIEW Runtime.
I suspect the problem may be related to missing or incompatible ActiveX controls, as I do not have the LabVIEW ActiveX Controls folder on my system, which some older HMIs require.
Has anyone encountered Error 537300 in a similar situation, or found a way to fix it without access to the original LabVIEW project?
Any advice or pointers would be greatly appreciated!
(503 Views)
Hi Aaron,
The error code 537300 belongs to the "user-defined" error code range.
So to know what this error code means requires to have access to the source code or to the full documentation of your program…
(494 Views)
