Error 56
What does this error mean? What do I do to avoid it? The error occurs in this subVI, but if we continue the main VI runs but with failed communication between NI hardware and LabVIEW.
(2,941 Views)
Hi shreya,
now you will be flooding the forum with threads named just "error xxx"?
The error description is given in the error message dialog: "TimeOut". Don't you read your own screenshot?
As it occured at TCPOpen most probably the server didn't answer in time…
(2,935 Views)
