Error 6 occurred at GPIB Write in test_terminator.vi Possible reason(s):
What is the cause of that error:"Error 6 occurred at GPIB Write in test_terminator.vi Possible reason(s):LabVIEW: Generic file I/O error.
NI-488: I/O operation aborted."
We are trying to communicate with a device throughout a GPIB-488.2 card.
(5,621 Views)
Reason : A possible reason could be that the instrument didn't have enough time to receive the command you've tried to send.
What to do : Try and increase the timeout value for the GPIB communications.
I had the same problem when sending configuration commands to oscilloscopes.
Hope this helps !
Julien
(5,621 Views)
Julien is probably correct. Take a look at the following KB that descibes possible reasons for the many different errors in gpib, and EABO (6) is one of those.
http://digital.ni.com/public.nsf/websearch/2FA525A8585A92E9862566EE002A3755?OpenDocument
Steven B.
Applications Engineering
(5,621 Views)
What if I have disabled timeout but I still get  this error?
(5,227 Views)
Did you refer to the linked KnowledgeBase article here? It lists a number of other possible reasons for EABO 6. Let me know how it goes!
Rasheel
(5,204 Views)
