Error 6
I recently upgraded to LV2009 and am trying to run programs that were written with LV8.6.1.  I have relatively simple subvi's that use the 'read from spreadsheet file' node but everytime i run them I get the 'attached' error 6 message.  Any suggestions regarding a solution would be appreciated.  Thanks, John
(4,037 Views)
Are you SURE the file is tab,comma,space delimited?
Ben
(4,033 Views)
Paths (stored as constants, locals, globals, in files, etc) may have changed now that your LabVIEW (2009) is in a different directory than it used to be (8.6.1).
Also, Read from Spreadsheet File is a VI, not a "node". Check your hierarchy and make sure things are linked properly.
Richard
(4,022 Views)
The files that I am currently reading from are space delimited and as you can tell new to LV2009 and upgrading LV from a previous version.  Could you send me an example of a properly structured file hierarchy or suggestion if possible so I could compare it to mine??  I will be investigating path search you have already suggested in the mean-time.  Thank you for the help.  John
(4,006 Views)
Go to the Hierarchy ("Alt+V" then "H") and then turn on "Full VI path in Label" under the View menu (or go "Alt+V" then "P"). Hover over VI's and make sure they are the expected filename & path.
An easier way for a quick check of paths (if you use the Project structure) is to turn on the "Show Item Paths" under the Project menu.
Richard
(3,974 Views)
Accepted by topic author Newton2this
Thank you!  The 'alt-v' then 'p' trick definitely helped.  I will compare vi paths with the previous hierarchy in LV8.6.1.  Have a good day!  John
(3,963 Views)
