Error 61017
I can run FPGA target under the "cRIO 9073" chassis in "Labview FPGA Interface Mode".  When i added digital I/O modules (NI 9421 and 9472), "error 61017" has occured. And these modules must used in "Scan Interface Mode" but this error occured  in this mode. How can i fix this error?
(4,089 Views)
Accepted by topic author MehmedERSOY
Hi Mehmed ERSOY,
Did you try re-compiling your FPGA VI?  If you added a module in scan mode and also have modules in FPGA mode, then you'll be running the cRIO in what's known as hybrid mode.  In this case, the FPGA will actually have to configure and combine the Scan Engine .bit file as well as the .bit from your FPGA target build.  If you haven't recompiled the FPGA build, then it's possible you will see this error.
(4,044 Views)
